hey guys,
I left my lights on last night and this morning my battery was completly flat.. When trying to jump start it the car just clicks like crazy? any ideas how i can get it purring again?
Is there some special way to charging a skylines battery? ><
https://www.sau.com.au/forums/topic/182455-r33-series-2-flat-battery/
Did you try and jump start it using the terminals in the engine bay? or straight onto the battery in the boot?
I've jumped mine straight off the battery in the boot before I found out what the terminals in the engine bay were. Worked alright.
That clicking sound might be your starter motor. Are you jump starting off another car or a standalone battery?
Positive on positive. Negative on negative.
Hahaha.
I am connecting to the battery in the boot? is that where i should be connecting?
I was using my neighbours 83 ford laser to jump start ha-ha :P
Car was completely dead when i came out.. put jump leads on and i got dash lights back but when i tryed to turn it over it was clicking like a machine gun ;)
Hahaha.
shouldn't matter where jumping from, but the points in the engine bay near the fuse box are easy to access. Make sure you have good size cables and a good connection on the clamps (this makes a massive difference). Failing that, the ford laser battery is probably crap and does not have enough cranking amps for the skyline. Call your local RACQ (not sure wat its called in WA) or find a bigger car/battery and try try again.
Make sure the laser has its engine running as well. You can try leaving the two batteries connected for a few mintues, the two batteries will try to equalize their level of charge, and the bigger skyline battery may have enough umph to crank but its not recommend to leave them connected longer than required.
The clicking sound is the starter motor using more amps than the battery can output, it starts to throw the solenoid out and turn the motor then it overloads the battery and turns off do to lack of voltage (voltage drops when you crank).
Edited by 33driver
If you pop the bonnet, there's a black box on left side of the engine bay with jap writing all over it. It has a diagram of how to jump start from that box. You've got to pop the lid off to get to the terminals.
Try jumping from that one.
Edited by KeyMaker
shouldn't matter where jumping from, but the points in the engine bay near the fuse box are easy to access. Make sure you have good size cables and a good connection on the clamps (this makes a massive difference). Failing that, the ford laser battery is probably crap and does not have enough cranking amps for the skyline. Call RACQ or find a bigger car/battery and try try again.
I was thinking the ford laser battery might be shot too, but it shouldn't matter if the laser is running while he's jump starting. The volts/amps should be boosted by the alternator. Revving the laser while jump starting can help with this.
Edited by KeyMaker
Okay cheers guys, i thought there might have been something more to it.. like since 100 cars ive jumped start first time i thought cause its an import and the battery is in the boot there might have been a different way of starting it.. so yeah i got a battery charger ill take the battery out tonight and charge it over night and hopefully that should fix it ;)
While the alternator will help, I suspect a ford laser may have an alternator of like 80amps max, starter motors can draw like 400+ amps for the split second they crank, if the skyline's bat is dead flat and the ford's isn't in great condition the voltage will drop too quickly across the connection for the skyline to start. but meh getting techincal now - chuck the charger on there and it should be fine
Hahaha too true. I stand corrected ;)
+1 for the charger.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
