well with the impending sale of my R32 i have for sale a few items that are taking up space in my garage. all items have pictures which are located here: http://www.skylinesaustralia.com/forums/in...howtopic=182464
V35 350GT wheels
- stud pattern is 5*114.3 (same an R32/R33/R34)
- fronts: 17*7.5 +30 with 225/50/17
- rears: 17*8 +33 with 235/50/17
- came off my V35 350GT when i bought it
- nissan centre caps
- NO gutter rash, scratches, or anything. they are in absolutely immaculate ondition - see for yourself
- 90% tread nankang tyres, completely roadworthy
price: SOLD
AFM from an rb20det
- this is a working AFM from an rb20
- will work on any rb20 or series 1 rb25
price: SOLD
AAC valve from an rb20det
- this is a working AAC valve from an rb20det
price: $20
Universal automatic shifter
- this was used on my R32 GTSt automatic for about 1-2 years
- GREDDY racing performance
- looks great, makes the interior look a million bucks!
price: SOLD
Universal hand brake handle cover
- silver
- unused
- looks bling ;)
price: $15
standard R32 side idicators + globes
- 2 * standard SIDE indicators off my R32 gtst
- orange with globes
price: SOLD
Justjap catch can
- has a few scratches and the rubber tubing (oil level indicator) has copped a bit of engine bay heat making it discoloured a bit
- silver
- filled with stockings and steel wool
- has removable top and bottom and plug to drain it if you need to
- looks great in any engine bay (i only had it as a bit of bling)
- comes with about 1m of hosing
price: $30
Beltronics laser detector
- Beltronice vector 945 radar detector
- these are >$500 new
- comes with car adaptor - 2 wires that needs to be spliced in, +12V and ground
- for more info: http://alatest.co.uk/apps/reviews/533535/-...Laser+Detector/
- note: these are legal to buy / sell in any australian state, and in some australian states are legal to use (please check your respective state yourself)
price: $90 + postage
all items are located in New Farm, Brisbane.
I am willing to ship small items at an extra expense but for large items like the wheels pickup is the only option
images for all items are below
to contact me, send a PM - i usually check the forums daily.
thanks,
Warren
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/182465-fs-r32-r33-v35-and-universal-parts/
EDIT:
for some stupid reason i cannot find the beltronics car charger and maual, they are put together somewhere! argh!
i will have to hold off on the sale of it until i can find them
Warren
EDIT#2:
ok so i found the connector. it doesn't run off a battery it runs off the +12V source continuously, and it had been previously connected by being spliced into 12V from behind the dash
as a result, it doesn't have a cigarette lighter adaptor, rather a "+12V" and a "ground" wire which needs to be connected
also i can't find the maual
as a result of this, i've dropped the price of the beltronic unit to $90 plus postage
this is an absolute bargain for whoever gets in first..
cheers,
Warren
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
