Hi all,
I've got a R33 S2 and I'm looking to upgrade my exhaust to either a 3" or 3.5" turbo back exhaust.
I've apparently already got a HKS cat back exhaust, not 100% sure on size however. (only got the car Monday night).
What's my best bet? Should I just go to an exhaust shop and see what they can do for me? Should I keep the HKS catback and mix in other parts or would it be better to order a certain full TBE package from somewhere? I'm happy to support SAU suppliers if this is the case.
I'm in Brisbane if that helps.
https://www.sau.com.au/forums/topic/182781-upgrading-exhaust/
Thanks for the replies.
Looking at the Just Jap website, would this combo be a good option to use with my current HKS Catback.
JJR Split Dump & Front Pipe - Nissan Skyline R33 GTS-T Price: $269
High Flow Design - 3 inch Stainless Steel
X-Force 3 Inch High Flow Cat - Nissan Skyline R33 Price: $199
Flanged - Flows up to 570 CFM
Would such a system be legal - db wise?
Edited by Simmo1985
If your current exhaust system is quiet now, then after you add the dump/front pipe and high flow cat it'll be the same. The cat back controls most of the sound.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
