Hey guys,
I got Work lock nuts on the front of my car, (All 10 studs, luckily the rears only had standard nuts)
Went to calder last Saturday and lost my box which contained the rest of the locknuts and the key-socket to remove them.
Was wonderring if anyone had one I could borrow/rent (the shape doesnt looks too fancy so I'm hoping all work ones are the same) The person that lends it to me can keep the Locknuts as they are useless to me without the key.
I got new rotors and want to install them :(
I know tyre places can bash them out...but trying to save some cash.
Or if anyone can point me to where I can get a new lock-nut key that would be great
https://www.sau.com.au/forums/topic/182995-wanted-work-lock-nut-key/
also if you cant get em of
get a chunky flat head screw driver and tape it up with electrical tape so you dont damage your wheels. rest it on the nut in the center and a few quick hits with a hammer and it will crack the nut.
