GENRAL INFO
Hi guys thinking of selling the beast. The full list of specs are below, the engine and gearbox where personally imported from Japan. All work has been carried out by 101 performance in slacks creek. The car has been safely tuned at 1bar producing 323RWHP. Has Mod plate for the engine conversion, 6 months rego, gets washed once a week serviced every 5000kms with the best oils. The car is in excellent condition inside and out, have spent well over $20,000 in modifications. I have just lost my liscence for 9 months hence the reason I am selling however I am not fussed if the car sells or not. I am not after any swaps just cash please do not make any offers as the price I want is firm and very reasonable. Located on the Gold Coast
DETAILS
• Full canary yellow respray (inside door jams, boot and engine bay + all panel bolts where replaced at the same time as respray)
• Boot wing removed and shaved
• Mesh Vented carbon fibre bonnet
• Full BN sports body kit
• GTR head lights
• Clear indicator lights
• LED custom tail lights
• 5% tinted windows
• 640RC (G-Force) number plates
• R33 GTR gearbox (custom tail shaft to suite RWD etc, box has just been replaced)
• R33 GTR engine
• Engine 6000km old
• JE pistons & ring set
• Shot peened conrods
• Race series main & conrod bearings
• ARP rod bolts
• Balanced engine
• Acid bathed block
• All new gaskets and seals
• Port and polish
• Full head service ect
• Rebuilt high-flow steel wheel turbos
• Splitfire coils
• White face dials (Nismo style)
• White face Autometer boost gauge (mounted to pillar)
• Greddy E-manage programmable ECU system
• Greddy turbo timer
• AVCR electronic boost controller
• Tomi gear knob
• Nardi sports steering wheel
• Aftermarket Alloy foot pedals
• 19” GMAX deep dish wheels (shadow chrome with machined alloy dish) front: 235/35/19 rear: 265/30/19
• After market heavy duty suspension (really stiff)
• Pioneer head unit
• 6” splits
• 6.5” AXIS parcel shelf speakers
• 450RMS brand new Alpine mono block amp
• 2 x 12” Kenwood subwoofers in custom box
• Full wiring kit
• 3” turbo back exhaust system with big cannon
• HKS intercooler with custom 3” stainless steel piping
• Turbosmart BOV
• Aftermarket twin pod filters
• Walbro 255/lh fuel pump
• Heavy duty clutch
$19,500 FIRM
Thanks Jake 0423771735
Edited by anyone
mate this thing is tough as nails.. with all the money u have spent should keep it
thanks for the comment, Im not fussed if it sells, I thought id put it up to see wot sort of interest it gets. Only problem is its so hard to resist not to drive it and if I get caught again ill get 2 years.
  • 2 months later...
well hope the car dont go yet coz im coming down brissie soon.
Im not in any huge rush to sell hence the reason I only have it advertised on this forum. Im sure it will still be around. cheers
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
