hay all. i picked up a coupe r34 skyline, 2L non turbo automatic. slow az! but i just put in a rb25det engine and pickd up a manual rb20det gearbox, all i got is the engine and just the box, what else do i need? 5months ago i didnt no what a starter moter lookd like. so i not doing to bad so far... i think?
You should of picked up a RB25 gearbox. The RB20 box will be a little too weak.
na all the pro drifters r getting them. i resurched it and the rb20det is inly weeker in 1st and 2nd gear, well thats what i got told.
oh and what color should i paint it? its a tos up between mitellic orange with black bonet, black roof and black boot or all matt black with bronze or gold mags>?
na its was only a neo 2L. maxd out at 40kmh up a hill. no grunt
Fact: Non-Turbo R34's come with a RB25DE from the factory. The RB NEO engine is 2.5L.
I find that very hard to believe.
I don't think you researched it properly. Mate up the gear box to a RB25DET and it will be extra weak.
There is a section on the forums too discuss cosmetics. Please use that section for more info and advice on paint colour etc.
oh nyc car dude. dig da wing ae
Please type out your posts in English.
Using "ghetto" style spelling from "da hood" will make you a target of abuse.
Please use the search button first before asking questions, as your questions may have already been asked and answered at an earlier stage.
Do yourself a favour and get yourself an RB25det gearbox. It will be a waste of time and money if you put the rb20 box on.
i asure you it was only rb20de. it was a v series or somthing. its a N.Z car not au
Well how'd you be. They do exist. The R34 GT came with a RB20DE NEO motor.
They must be rare as hens teeth. I've never seen or heard of them in Australia or Japan. Goodness knows why anyone would buy one. Hence the conversion I suppose.
Sorry for implying they never came with one. I stand corrected.
lol @ r34 with RB20DE.
i feel for ya, i really do.
as for gearbox, get rid of the rb20det gearbox and buy an rb25det one. will save hassles later on.
dont forget to upgrade brakes, driveshafts etc if u want more power, as they will be shithouse.
hay thanks. yeah i thought i might have to up grade brakes and all that. but its already 5 stud. would i still need to upgrade the brakes? as for the gearbox im hoping it will hold out until i can afford the money to get a rb25det. they are very expensive. hardst thing about this gearbox is trying to get a drive shaft that will fit a rb20det.
yeh i wouldnt wanna have an rb25det with rb20de brakes...it'd kinda suck. especially if u plan on making more power. id do all the brakes first before u decide to make more power. doesnt matter if its 5 stud, thats just the hub, nothing to do with braking. so you would be better off getting disc's and calipers off an R33 or an R34 with the rb25det.
hay thankyou for that info. im sure i can find them easy. but i honistly cant find loom, flywheel, and all the clutch stuff, like pedal and a fork thing and everything else thats goes with clutch. any ideas where i can get them from? iv tryd reckers and places. but nothing! please some one help me out on this one! thanks
Kudos Motorsports has a complete R33 auto to manual kit.
Maybe he can separate the bits you need. Maybe not. He might not want to separate.
http://www.skylinesaustralia.com/forums/in...howtopic=173377
I would of thought NZ had some import wreckers over there to get parts from. Otherwise you'll have to source them from wreckers here in aus.
Try Nisswreck.
www.nisswreck.com.au
Edited by KeyMaker
  • 1 month later...
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
