  • Replies 51
Pre payment just completed for 2 ppl: 2x$35
Paul you should have received my sms with the details.
Ray
sorry for the late reply we just got back from autosalon what a mission
we have received the payment thanks
Woohoo!
i came 3rd place with 223rwkw --> $150 A&B Voucher :)
(ran in 4th gear, bonnet down, temp sensor in correct position AT & IT was only 2degrees difference.)
Well organised, friendly bunch of people who know what they were doing.
Cost: $35(pre-paid)
-Dyno Run plus 2 prints out 1. Power vs Air/fuel ratio 2. Power vs Boost
-Unlimited FOOD +DRINKS (BBQ+BEER!!)
-Prizes!!
what more can you ask for from a dyno day ??
Will definately be going to the next one in the future (i think they are holding one just before xmas)
First Place: i believe was this custom converted convertible Datsun 260z made 380rwkw!!
2nd Place: 180sx/s13 making 228rwkw.
Woohoo!
i came 3rd place with 223rwkw --> $150 A&B Voucher :thumbsup:
Cost: $35(pre-paid)
-Prizes!!
Congrats Ray! :)
I was there, 2nd car to be put on the dyno. I got 145.5kWs with my car. Not much in comparison to the top 3, but considering I was expecting 130-140 I was very happy :).
Would of stuck around but I had a party to attend, and my dyno sheet to show off :rofl:
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
