Cleaning out my garage from previous wreck and also other parts that i found laying around.
S2 Driver side window switch - SOLD
Passenger side window switch - $50 (S1 & S2)
S1 Rear seats - SOLD
S1 Front seats - $150
S1 Factory floor mats - $50
Turbo dash cluster 137k kms - SOLD
Dash console/facia - SOLD
Factory CD/tape player with plugs - $70neg
Inner pillar cover thingy - $15 each
S1 Inner quater trim - $30
Door trims - $60 each
Boot trim - $60 (includes battery cover and floor carpet)
Gear boot - SOLD
Driver side window - $50
Climate control unit - SOLD
S1 M spec front bar white - $200
Chrome grill - $50
S1 headlights - SOLD
Bonnet - $150
Also have a lot of plastics and interior bits just let me know what u wants.
All parts are in syd. Would prefer local pick up but will post some parts.
0416 554 283
post-39634-1189746453_thumb.jpg post-39634-1189746535_thumb.jpg post-39634-1189746584_thumb.jpg post-39634-1189746639_thumb.jpg post-39634-1189746708_thumb.jpg post-39634-1189746778_thumb.jpg post-39634-1189746838_thumb.jpg
Edited by KK's-R33
https://www.sau.com.au/forums/topic/183618-r33-parts/
