Im planning to put an RB25 on my R32, still trying to source a good engine, but in the meantime I thought Id ask whereI can get this done.
Im sure plenty of you guys have done the same in the past, so please point me in the right direction, I got quoted so far $2500 just in labour at a well known workshop, which I thought it was I bit steep.
Any info would be apprecited
Cheers
Ric
https://www.sau.com.au/forums/topic/183635-engine-swap/
U are up in the hills right richo? The place where luke got the 25 and gearbox put into his 31 is down north near his place, but id go to them for anything, great guys and awesome work, and im positive they would charge alot less than what u got quoted. Just means u will have to take car out north
Edited by *flick*
https://www.sau.com.au/forums/topic/183635-engine-swap/#findComment-3326327
hey Flick..Nah Im in Unley now, so its not too bad. How far north is this? PM me details if you can, sounds good.
What sort of tools are needed for something like this? I have just the usual, not sure thats going to be enough.
Engine cranes are not too expensive these days anyway, so that shouldnt be a problem.
And I need to swap the loom, do I? stuff like wiring is what scares me :)
Other thing is the time that i would need to do somthing like this, G1 is coming in 4 weeks, ideally would be to have it ready in 2 weeks just in case.
Cheers
Ric
https://www.sau.com.au/forums/topic/183635-engine-swap/#findComment-3326375
And I need to swap the loom, do I? stuff like wiring is what scares me :yes:
I know how you feel.
Im currently pulling out the
ca out of an S13 (mine) for an Rb20 and the
Rb20 is coming out of an R32 (friends) thats getting an Rb25.
So far the rb20 is ready to go into the S13 and the rb25 is almost ready to go into the r32.
The wiring side of things is something that I have NO idea how to do, so getting a pro to do the s13 $150ish is the quote and R32 I bought a loom from Japan that had already been converted to run an Rb25 and then getting a pro to do the little bits and pieces to make it tidy, $300ish including the loom from Japan.
Everything else has been easy so far and as long as you do the research before hand you shouldn't have any problems, just leave the wiring to a pro and do the other bits on your own.
As for tools I used a $70 tool kit from K-Mart to pull the ca out no problems at all and had everything I needed. You will be surprised how much doing research helps and makes it look easy if you have a step by step guide. Give it a shot, you can always get it towed there later.
Edited by JiN_MaN
https://www.sau.com.au/forums/topic/183635-engine-swap/#findComment-3327374
The $70 tool kit included something to lift the motor out with?? :S
lol smart ass. Guy who bought my engine had a crane, I got him to bring it with him and then pulled it straight and onto the trailer.
You can rent then for $50 a day from kennards if that helps. If you have it all ready you should be able to pull it out and put the other in in a day.
https://www.sau.com.au/forums/topic/183635-engine-swap/#findComment-3327406
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
