UPDATED 27th October
Nismo R32 GTR Exhaust
Very Good condition
80mm Full Stainless Piping
Cast Stainless Flanges
Carbon fibre finisher
Mandrel Bends
Free Flowing but Quiet around town
Will support up to 350kw
Big $$$ new
$SOLD
PAIR of FRESH, FULLY REBUILT and BALANCED GTR turbos (Have not been fitted since rebuild)
These will fit R32, R33 and R34 GTR with no other mods.
The cores have been upgraded to steel exhaust wheels / shafts, 360 degree thrust bearings and step gap oil rings to ensure realiable delivery of higher boost pressures. Turbos have been VSR / Balanced.
Wastegate actuators have 2 settings. Have seen 300awkw on the same spec turbos.
Included is a Power FC File that made a safe 280awKW on my R32 (Std injectors and AFM's). If you have larger injectors or AFM's you may need a minor clean up of this tune - but the bulk of the work has been done - an hour or so on a dyno should do it (rather than 3 ~ 4 if you were starting from scratch). If you are interstate I can still load the file onto your FC if you send it to me.
Standard GTR comp cover / exhaust housing (.42 / .48)
Unleash the pontential in your GTR!
$(ON HOLD)
PM or Email Me -
[email protected]
Good set of clean Factory R32 GTR Rims
16x8 - forged
$(ON HOLD)
Edited by Antimatter
The cores have been upgraded to steel exhaust wheels / shafts, 360 degree thrust bearings and step gap oil rings to ensure realiable delivery of higher boost pressures. Turbine wheels flowed - Turbos have been VSR / Balanced.
Rated at approx 500hp - Same spec turbos have deliverd 300kw @ the wheels with minimal other mods on RB26 (Exhaust, Filters, ECU and FMIC)
$1700 the pair + Delivery
Are these off a R32/33/34? can you pls post the model #. Also the pics you have are from ebay? Do you have actual closeup pics?
Thanks for your message.
Serial from tags is 14411-06U20 and 14411-06U21 (this will only tell you what the cores began life as anyway)
I beleive them to have originally been CERAMIC TURBINE WHEELS off an R33 (have since been rebuilt and upgraded to Steel Turbine wheels, 360 degree bearings etc).
These are the pics of ebay (that was my listing). If anyone is interested I will be re-listing these soon if not sold prior.
Can email hi res images on request.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
