+1 what Chops said - it actually was not so much BJs fault at all .... BUT he should either spend a shitload of money on the track, digital signboards, infrastructure, etc etc, or sell it to someone like Bill who actually wants to pour money into it and bring Adelaide back to the once mighty drag town it was.
When i was in melbourne a few months ago i was speaking to my friend about Calder Park. He said that Bob is planning a major overhaul of both Calder and AIR.
He only knew a small amount about the AIR renovations, It will be getting digital signboards (ex calder displays), resurfacing of the whole track and some facility upgrades aswell.
He has put a huge amount of money aside for both tracks, however i feel Calder will get the majority of the money knowing the plans they have for the Melbourne facilities.
and the feeling i got from my friend (who is close to Bob) is that BJ wants to get the 2 tracks up and running to their full potential as both open track days and state level motorsports. At the moment Calder is open at least 1 day a week for free practice and bob wants to bring this sort of public access to AIR.
I will dig for some more info and let you know what i hear.
As Miss34 said, words are cheap.
I heard all this stuff 2 years ago.
  • 4 weeks later...
Bob is definitely keen on getting his tracks back up to national standards. The work on Calder is 30 - 50% done now with new race control facilities, resurfacing, new timing boards (old one heading over this way).
Work on AIR should be starting soon after work is finished on Calder. So it will still be a while off as there is strong talk of extending the track over there.
will keep on looking further to try and find the exact plans around Air - resurfacing the whole track & drag strip is in the mix at the moment
Interesting yes, but still the EXACT same story I heard in 2005. Let's hope they mean it this time.
I'd almost rather they came out and said "we're doing nothing, it will never open again" than the chinese whispers.
Edited by chops
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
