  • Replies 95
Posted Images
it's just sucks cops had to pick on you! but it didn't look like there was gonna be anything crazy because of all the po po in the hills!
but i think it was deluxes car! sounds freaken mad!
Cheers fella, That was obviously you behind me there!
Still can't believe i locked it up twice behind Ryan, and close to where the cops were too! and then just missing a Koala was good also!
You woulda thought lesson first time. :( I point at u deluxe, if u hadnt called dan we'd be chilln at hes house and never seen no 5-0 :spank: hehe
See ya all out again soon.. (after the show is finished)
BB x
hmmmm that beach whale that still makes your fart noise 180 look silly, and the fact you want a beached whale engine, and if you like i will just take my poor little gfs car and still go "munch munch katana for lunch"
Fart noise ? Its not N/A :D
Poor little gf's car, bullshit you want just one like it !! Little-Yellow-Evo-bitch, you gonna start wearing heels now or are you just going to wait till you get to entertain all the troops... ;):D
And yes...yes i do infact want a beached whale engine, should be in very soon :(
Edited by barricade
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
