  • Replies 256
Posted Images
Are mine working ..pics that is
And were are your pics .? Dont tell me you didnt take any....
Oh thanks, Wayne! Damn I am getting OLD! :thumbsup:
BTW thats my son ADAM -(xR34x) Black R34 with the BLING wheels right behind me!
Cant belive I was following a skyline 4 dr exactly same as yours over the Westgate and flashing lights at him.
Dont know if he was more surprised than me when I realised it was not you, pulling alongside!
Will put my video here later.
The day was friggin sweet!!! Couldn't have gone better. No police intervention, no accidents, and so many cars! I would have loved to have heard the convoy from the outside on the gor, would have been soo loud!
Redlining some of the later gears was fun :down:
Definately missed out if you didn't come :thumbsup: , anyone take any pics in the car whilst on the actual gor?, some of the twisties would have looked awesome in phtotos when you could see the huge snake of cars through the turn.. great day :)
My girlfriends mum lives at Aireys Inlet about 200m off the highway and could hear the convoy loud and clear ! :thumbsup:
Edited by SNISMO
I was first there this morning
So i had people asking me things when they got there.. Like
Where do i get a SAUvic sticker for my car
How do i get a SAU shirt.
So i explained about the club and some thought they were members of SAU and some didnt even know about it(The club)
Then i read in here how things like .
Finally glad to meet other GTR owners
That was the first thing i have done with my Skyline
I cant wait till the next 1
GUYS GUYS GUYS...Become a SAUvic member.............Its the way to go
So So many benifits the list is endless..Kind of.
Have a look at the SAUvic web site
SAUVIC WEB SITE
And here is a membership form
MEMBERSHIP FORM
Hope to see you guys soon..
Cheers Wayne
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
