I can't stand Wiseman's. I don't like driving on a road with no lane markings, and its as choppy as all hell.
I only encountered one HWP on Pac yesterday, but that was when me and a few other sports cars were parked on the side of the road so I'm sure we were conspicuous. It was just after lunch time on a weekday though.
https://www.sau.com.au/forums/topic/184274-oldpac/page/2/#findComment-3339996
If only......
The locals would bitch and moan if you did that, even if you cut them in on the fee. They were probably the biggest force behind getting Race to the Pie cancelled, even though there's no houses on that hillclimb between Mooney and Pie in the Sky.
DARN LOCALS! *shakes fist*
https://www.sau.com.au/forums/topic/184274-oldpac/page/2/#findComment-3340072
Yeah but they are starting to resurface wisemans according to the local council ;) Il believe it when I see it!
Yeah old pac during weekdays (well Mon - Wed @ least) is usually quiet... except in holiday times! There are only 2 HWP on duty Sunday & monday nights and not much more during the day - thats Gosford to Hawkesbury anyways..... Hornsby side can be a bit worse...
https://www.sau.com.au/forums/topic/184274-oldpac/page/2/#findComment-3340077
great idea, il sign a petition for an event or regular course but good luck with legal aspects.. know of any commercial or residential requirements up there ?
doubt both being a reservation but it happens.
would require allowance for the lowest common denominator aka ambo etc.. but sounds like an awsome idea that would never be allowed. but make the price $5 for a run.. its not that long !
https://www.sau.com.au/forums/topic/184274-oldpac/page/2/#findComment-3340628
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
