due to a sudden change im selling my rims.
RacingHart's CR
they have 75% bridgestone potennas all round.
18x8.5 +21 235/45/18
18x9.5 +21 275/45/18
location ; sydney
Price Drop. $1800
Edited by SoFly
https://www.sau.com.au/forums/topic/184323-racinghart-crs/
Can you let me know which Skyline they came off and if they will fit a 96 S2 GTS-T.
RacingHart's CR
location ; sydney
$2500 firm.
https://www.sau.com.au/forums/topic/184323-racinghart-crs/#findComment-3339037
looking to swap your rims? i have some veilside 17x9 +17 deep dishies +700 your way. i dont use this forum, sms or call 0421 720 618 or email [email protected]
can get you a link to pics tomorrow, theyre on nissan silvia in the members rides on my soarer
https://www.sau.com.au/forums/topic/184323-racinghart-crs/#findComment-3352423
  • 3 weeks later...
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
