hi, i purchased a rb25 ( turbo) long block for my car about 6 months ago unsure of whether it was a s1 or s2 engine.. i only recently finished installing it into my car.. today i went to start it and it wouldnt start.. now my original engien in the car was a s1 so i plugged everything off my s1 engine onto this new engine.. i have some doubts that it could be a s2 engine because the coil pack cover was slightly different at the back to the one that was on my s1 engine. now if the engine was a s2 engien would assecories come on if i put the key in? i'm going to change the battery tomorrow to see if that is the problem but i would like your thoughts on the matter..
thanks
https://www.sau.com.au/forums/topic/184678-need-help-engien-not-starting/
no fuel pump priming and no starter motor going..
Yeah just double check everything battery, earths, connectors etc. You should still be able to see the dash lights when you put the key in. Can you hear the starter motor going or the fuel pump priming? or is just totally dead?
ok i bought a new battery and installed it... i checked thoroughly to see if everything was plugged in and found that the earth cable wasnt mounted onto the engine.. I put it to accessories, the fuel pump primed this time. i go to start it and the started motor makes a noise once and then all the dash lights go off and have to disconnect the battery n put it back on to attempt again and still the same thing happens.. any ideas.. also checked all fuses.. all ok
there is good metal to metal contact and also the battery terminal is screwed on tight.. what i'm worried about is that it could be a series 2 engine and i've hooked up s1 ecu and s1 ingnitor module to the s1 coilpacks. But if it was a s2 engine would it be priming the fuel pump if it has the wrong ecu in it?
The engine doesn't mean anything
If you have a Series 1 ECU, loom, Ignotor pack, and coil packs, then it will be fine.
You might have to think outside the square. Grab a multimeter and go to town!
Tried a different ECU?
i havent tried a different ecu, however all the sensors and ecu and loom were all workin on the other engine. the only thing that i can think ov would b that i have a series 2 engine with s1 components on it. also i wouldnt know where to start with the multimeter ( never used one before)
mate, the Head and block in the Series one and two would have no differences.
Only the wiring loom \ ecu \ coil packs etc. So you've effectively downgraded the entire ignition system down to a series one, which will be fine. So a Series Two engine and head with a series one ignitor pack, wiring loom, ECU and coil packs would work fine..
Unless the wiring in the rest of the car to the fuel pump or something is different?
if you go back to one of his earlier post he says
the fact that you have a series 2 motor being controlled by a series 1 loom doesn't have anything to do with it. you swapped everything over. didn't you?
have you checked your connections to the starter motor?
its abit worrying when you say you wouldn't know where to start with a multimeter and your attempting to fault find a clearly electrical fault. i'm not having a go at you, everyone has to start learning somewhere.
to me it sounds like you haven't got enough power going to the starter. bad connection somewhere? altenator to starter motor connection?
nah nothing else is different.. i'll give it another check over tonight when i get round to it and post results.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
