was sitting stationary this morning and saw steam come out bonnet, i look down at temp gauge to see it almost in the HOT area... so i like mounted the kerb got out and poped the bonnet.
it spat out the coolant out the overflow, the overflow was empty but not sure about the radiator level.
let it cool down for 5 minutes, started it back up and drove it down road to automasters, they are guna look at it on friday.
does this sounds like a thermostat issue? this is the first problem iv had with the car and its so sudden.
are the rb20 heads strong, surely those few seconds was not enough to warp the head. it started and idled fine afterwards and it didnt shoot straight up to the heat either, even after 3-4min of running.
https://www.sau.com.au/forums/topic/184728-rb20-overheated/
when it cooled down did the radiator have coolant in it? what kind of fan set up do you have? if clutch fan, make sure its not seized, if thermo, make sure they are doing there job well by putting your hand in front of radiator to feel air being pulled through the core at a decent rate rather than a slight breeze. Wouldn't hurt to flush the system and put fresh coolant in as well.
you may have a leak if the overflow was empty and was previously full, unsure whether it may or may not be thermostat. I would check these things first.
Edited by gibbau
https://www.sau.com.au/forums/topic/184728-rb20-overheated/#findComment-3346219
i got a call to be told the water pump is leaking, i contacted the old owner and he asured me it was replaced 15 thousand kms ago...
im going to get them to do a oxygen test on teh coolant to see if its worth replacing or chuck the motor away.
strange.. i couldnt see it, spose that wat sucks about it behind behind covers.
https://www.sau.com.au/forums/topic/184728-rb20-overheated/#findComment-3346370
The rb20 heads are tough as.. :blink:
When I first bought my car years ago I unknowingly (due to a faulty temp sensor) had it running upwards of 120degree's for a whole summer. The temp gauge when the sender was fixed would sit on the H rock solid. And I wondered why it would spit water out in traffic lol.
How the car was fine I still have no idea; it went on to run another 100,000km's before I pulled the motor out; still making great power, excellent compression etc.
https://www.sau.com.au/forums/topic/184728-rb20-overheated/#findComment-3346395
timing belt was done about 15 thousand ago, has a stamp on there saying so anyway. looks to correct by the condition of the belt
by the time i get a tow truck which will be 130 bucks
go to my other house to collect the tools i need to do the job with fuel + the cost of a pump and coolant
may as well get them to do it :P
i was just trying to justify spendn that amount LOL so maybe if someone can tell me its a shit job and it takes days il feel better :unsure:
Edited by BANGN
https://www.sau.com.au/forums/topic/184728-rb20-overheated/#findComment-3346952
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
