Hi Guys,
I currently have an 1996 R33 GTST 4 door sedan(which used to be my old mans) with an rb26dett engine conversion and r34 gtt manual gear box in the car. The rb26 has got the following done before the engine was put into the car.
HKS Stage 1 Cams (which havent been dialled in)
ARC pistons
Eagle Conrods
N1 Oil pump
DBA Slottered Disks
Modified rb26 sump for the RWD
ARC(i think) metal head gasket.
R33 Stock Turbos on Stock Boost
3.5 inch Kakimoto Exhaust
3.5 inch High Flow Cat
3.5 inch Dump pipes
Apexi Pods
The car has only done now 2500kms after the conversion and also has a HKS Twin Plate Clutch with plenty of meat on it.
What I'm after im looking for are people out there who are thinking about getting rid of their GTR's (1997 or upwards and il put some cash your way towards the GTR) and swapping for another family sedan, possibly a r33 4 door with an rb26 conversion.........
Anyway lemme know, i got the feel of the wheel spin but now i want the G-force.... >_<
Around about figure im lookin for is around the $22,000 mark, from the work ive done on the car. Havent dyno'd it as yet but the mechanic anticipates it puts out about 220rwkw +..... and thats with Stock boost and the Cams not dialled in as yet.
I havent had a chance to change the engine no at the rta either since ive been interstate
The only other thing i can think of is that its got a little bit of hail damage from when my old man was driving it. Ive really treasured my pride and joy but now i want something a bit different.....
Lemme know, im happy to negotiate.
Rj
More pics added
Edited by 4drlvr
Please post a price as per classified rules
1. When starting a new thread, you must include a set price, or at the very least a ballpark figure that you are looking for. EOI's are not permitted, if you want to auction your gear then use e-bay
Sorry Jet32r, thats one beast of a car but im really after a 33gtr possibly a vspec.
Steve, will post up pic on the weekend.
Love the look of the 33gtr's for some reason espically the series 3's, but either way thanks for the replies guys and keep them replies coming
Rj
  • 3 weeks later...
Nope ..... the car was a turbo(rb25det) with an auto before the conversion, now its an rb26dett with a r34 gtt manual gear box.
Any offers...
don't mean to sound rude mate, but are you sure it's a 96 model? cause it is only running series 1 bonnet, headlights and interior. is it possible to get a picture of the factory ID plate.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
