Hi all,
Awesome drive last time to the highlands. Had some requests to do a Blue Mountains Cruise this time. So here it is.. =)
When: Saturday 22/09/2007
Time: 11:00am (Leaving 11:30am)
Meeting: at P6 Carpark, in the Olympic Park, Australia Avenue. (Near the train station)
Let me know if your interested.
https://www.sau.com.au/forums/topic/184964-blue-mountains-cruise/
  • Replies 69
which route will you be taking from P6?
I think straight on the M4 all the way.. Stop over at the servo on the M4, and then continue through.. Im sure some will have suggestions as they know that area better than me.
In route pending...
I work between Penrith and Mt Victoria every day so apart from the actual highway their isn't really anywhere worth going on a 'cruise' unless you go to the coffee shop down in Megalong Valley.
It's actually only about 25km past Katoomba (or about 13km from Blackheath) and the last 12km is extremely tight and narrow as the road snakes down the mountain into the valley which once at the bottom has absolutely amazing views of the high cliffs of the Megalong/Katoomba area. At the bottom is just a very small cafe but apart from that their is nothing at all to do there.
Road down to the valley
Base of the valley
A Heritage farm with demonstrations etc (admission price required)
View back up the mountain cliff
Edited by benm
I know the road you're talking about, down into Megalong. It's nice i always take it and stop halfway at that little track that leads down to a small creek.
I agree apart from the Hwy there isn't too much cruising track. The Megalong road will be fun if we take it though :laugh:
LOL, Awesome, you lot come to my backyard the weekend I'm racing at OP. oh well, shit happens.
My suggestion,
Head up Bells to Lithgow, lunch there would be the option if you leave Homebush at 11am, would make it around 1:30-2pm lunch. IF you can get away earlier then continue through Lithgow and head back towards Sydney for about 2kms on the highway. Then take a right out to Tarana where there is a ripper Pub to stop for a bit, kick arse steaks and pretty cheap too!
From there head back through past Jenolan Caves road, to the highway. Head for Sydney again to Katoomba, where Cliff drive down to Leura is a must do detour!
Once you rejoin the highway again then head down to Springwood, where you will find Hawkesbury rd on your left (I am forced to travel this road daily on my way to work) where you will find a 3.5km hill climb section about mid way along that I would kill to close and have a red hot go at hill climbing one day. You guys will be travelling down, but it is worth turning around and heading up just once, windows down radio's off, and there is a nice lookout at the top for a stop. Just don't go up and down too many times as the heat will make their way out eventually if you do.
Continue along this road and head for Richmond, and then head home the way you came.
Hope this helps, and that should keep the drivers amongst you happy!, heard that the Tarana road was recently resurfaced, so stiff springs shouldn't kill you any more.
Cheers,
Dan.
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
