I can't remember seeing you scando(ing) the start finnish straight, If you were id say not to do it! If you slide out of the esses then grip up, power down to the canteen and switch back there, bum drag it to the apex and power out! it seemed to work for alot of others! GT George seems to like to do too much of a smoke show down the start finnish straight, and when he gets to turn 1 he has to get on the brakes, seems his switch backs are too long or something!
All in all dude you had some good pace on!!!
I think you are confusing scandos with fishies :mellow: ....some people keep the drift going from the exit to the straight and keep fishtailing till the entry to turn 1..= FISHIES
Others, straighten the car on the beginning of the straight as you describe and half way down the straight do a Scando flick to the opposite side of the turn and back again into turn 1. = SCANDO
I think you are confusing scandos with fishies :) ....some people keep the drift going from the exit to the straight and keep fishtailing till the entry to turn 1..= FISHIES
Yeh your right i used the word "scando(ing)" which really isn't a word.....lol I meant Fishies!
hey rico, im keen for some tandems with you next day prac if you gonna be out there?
you too showza when you get back out there, any idea when you will be?
I'm trying! Finally got my head back, so putting engine back together soon. Wont make G1 but will be out at a grip practice on Oct 27th for my first lot of hard driving since G1 rd 2! :D
Next time drifting will probably be Dec Day prac cos I'm too cheap to pay for drift school :thumbsup:
Dunno if I'll be able to keep up with Simon and Hayden anymore... Was struggling before!
Edited by salad
well in that case you can tandem with me then :thumbsup:
ill make you look good if your worried about sucking lol.
pffft
[e-cry]
no one ever mentions my driving... is it cause my car is an utter thrashed out piece of shit 32 atm? i was out there driving the hardest i have in a long time and hayden also. we pulled some insane close tandems and no one cares!
[/e-cry]
^^^^^hahahaha good one!
You know you are good mate, noone needs to tell you that :(
You are the best out there everytime you are out.
But we'll try and mention you here from now on. lol
Cheers
Ric
Oh hold on......
Sorry had to be done
Edited by Richo
well think i mentioned on ns simon, but yeah sitting in lineup watching you 2 tandem was insane, you 2 are so good, and you get soooo close to hayden. Im dreading the day i ever come up against you in a battle man.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
