Hi guys,
Every morning and afternoon when I start my car up she squeaks like all buggery.
When I watch the PFC hand controller the squeaking doesn't stop till the volts read over 14 (takes a few seconds.) then she's quiet.
If I stop the engine, then restart immediately, it's fine. No squeaking. But goes to 14.7v almost immediately.
Should I tighten the alternator belt, and if so, by how much?
Or is something else wrong?
This problem only started happening after I got my car back from the panel shop after 4months...
https://www.sau.com.au/forums/topic/185246-squeaky-alternator-on-startup/
Actually you could take your air con belt off and switch it over to the alternator. They are all very simiar lengths.
Yes you do need to tighten it but also try putting some pure soap (not bath soap) on the inside of the belt. If the squealing comes back after getting it tight and the soap then replace it cos the squealing it's already done has damaged it.
OK, I think I'm going about this all wrong.
This long bolt was loose, almost falling out. I've tightened it. BUT, tightening it doesn't make sense to me. Having this tighter means a looser belt.
What am I supposed to do?
Loosen bolt 2, then pull the alternator towards the guard?
Tighten 1 slightly, but not all the way, bolt 2 is the tention thingy which when tighten moves the alternator towards the guard. (ie. tightens the belt). Tighten bolt 2 to the tention u want, then tighten bolt 1 to "lock" the position in.
  • 7 months later...
just a noob question...
but isnt the clutch fan ment to turn off like after awhile???
or nope becaoz it on the same belts as the alt. belt too.
so yeah?is it meant to turn off wen it gets to a normal operating temp?
becoz i just got my timing belt done..and i notice the next day, i can hear a squeaky sound from the front part of the engine..
so i assumed it was my timing belt...
but now being lik 4 days later..i dont think it is..
i think its the alt./fan belt
but could pwr str belt..
or air-con belt...
but unsure so far...
but one think i do notice is that the sound(squeaky sound) only appears to heard wen the enigne is at normal operating temp...
any ideas
what timing belt did you use?
me and a few of my friends have installed gates racing timing belts for our cars.
after the install, we noticed an extra whirring/squeaking/rotating sound added to the engine when the car is warm.
it's because of the new belts tightness, and over time it will loosen itself to it's perfect tension. if not, it will remain with that sound which isn't a bad thing. it might put a tiny bit of stress on your idler and tensioner, but i find it safer to have a belt a lil tight rather than a little loose.. especially at high revs.
Edited by dmr
Why would the clutch fan turn off, its on a belt that isn't going to stop while the engine is on :( ?
Anyway, the clutch fan will start slipping at higher RPM because the fan can't spin at too higher speed, and it will lock more and spin faster when the cars hot (at idle speed anyway).
well ive still got the same problem..lol
my cars done just over 1000k's with the new belt...
does anyone no how long it will b before the belt loosen to the original belt tension?
like as mention above and before...
people mentioning hear a squeak or sound from doing the t-belt..
and said it disapeared after a period of time..
if so..
how long is this time..lol
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
