Hey guys
just found out today i have been manned to do security at the GC Indy this year, did it last year had a blast. i'm part of the Army group that goes down every year so if any one is down there come say hi, will see if i can get you guys some VIP passes or some autographs from the Miss Indy ladies or something decent like that.
as always the role is STC, but it should be pretty concreate.
https://www.sau.com.au/forums/topic/185591-gc-indy/
lol.. indy chicks are hot broad minded persons.. i only pick up hot teen broad minded persons i want the more mature less clingy ladies
get in line
respect your elders bish!!
VIP :rofl:
CORP BOX :P
YAY!
pfft bastard...i am thinking you want to invite the SAU peeps too uhuh.,..right...
good on you
https://www.sau.com.au/forums/topic/185591-gc-indy/#findComment-3359784
  • 4 weeks later...
haha they did the chant thing the other year when I was there, across the balconies "BLUE TOP! BLUE TOP! BLUE TOP!" until the chick flashed (or not :spam: ) which I thought was funny until they started with PINK TOP and I realised they were all shouting at me :closedeyes: I was so embarressed i wanted to run inside :spam:
so anyway... VIP passes eh?
any left for Sunday??
https://www.sau.com.au/forums/topic/185591-gc-indy/#findComment-3420622
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
