Hey guys,
Had abit of a drama where I wasnt getting oil pressure which is soughted out now.
Basically what happened was an oil change, however the lines were switched around on the sandwhich plate resulting in the filter getting pressure going the wrong way, meaning no oil going back into the motor or some loss of pressure for 5mins. In other words the oil light on the dash was on.
The car idled like this for 5mins, at the same time i also moved the car around 20m up an inclined hill.
Long story short, fixed the problem, started it again and let it idle for 10mins to get the oil flowing back through the car as the oil pressure light was off.
Took the car for a drive, seemed fine, seemed to boost fine etc, and no loud abnormal noises when driving it and the PFC didnt record any abnormal knocking as the knock was around the usual 15. Once finished the drive, I popped the bonnet to see if I could hear anything abnormal and sounded like abit of a squeal which seemed to pop up twice over a 5min period for around 2sec intervals coming from the passanger side of the vehicle.
So my question now is whether the engine would have any damage on it from when it had no pressure? Hoping I didnt ruin any bearings, bent anything internally etc :thumbsup:
Car type: S15
Mods: 2871r, PFC, injectors, oil cooler + relocator etc etc.
https://www.sau.com.au/forums/topic/185602-no-oil-pressure-for-5mins/
You will have some bearing wear for sure as there wasn't any oil and you have metal to metal contact. How much wear/damage is anyones guess, don't forget there is oil in there but as you run it for 5 long minutes a lot of it would have gone , When you was runing the engine you should be able to hear some knock ..
The best thing to do would be to pull the sump out and check the bearings and the crank journals.
It definately wouldnt of done it any good thats for sure. The only good thing is that it was only idleing so the low revs might of saved you. i had a mate that wasnt very mechanically minded and decided to do an oil change on a 180sx with a sr20det, anyway he didnt tighten up the oil filter properly and on the test drive it popped off and he probably drove it for 10mins with no oil. I came around with a new filter and oil, topped it up and it was fine and its still going strond today.
Best case senario for you is that you have slightly worn the bearings which would of just taken a couple of kms of the life of the motor, nothing to worry about it. You could of pitted the bearings, which means they are damaged but havent spun yet, but since they are pitted they will be weakened and will be easier to spin on the next big rev you give it.
Its hard to say, but if i was you i would just drive it around, it should be fine but the second you hear any big end knocks, pull over, turn the engine off and get it towed home an stick a set of big end shells in it. Its a relatively easy job, you can do it with out taking the engine out if you have access to a hoist and shouldnt take you longer than 6hrs.
Edited by R34GTFOUR
Thanks for the reply Jerry & R34GTFOUR
So pretty much the case is that the bearings would have wear on them from what I can gather?
The engine was very healthy prior to this, turned up fine with leak down and compression test prior and has always been running on a healthy tune, so hopefully that and regular oil changes may save the bottom bearings?
Nothing to do with a healthy engine or not . You wont have any damage/wear on the bore or anywhere else. The only damage you will have is on the bearings , mostly big ends but can be on mains as well . I have seen people mark the bearings on a built engine the very first time they start it , thats why you should usse mooly grease when you assemble it in the bearings . As you hit the starter the grease will protect them until the oil pressure builts up.
Hopefully there was enough oil in there so you haven't mark them to much but if I was you i would pull the sump out and check them . If you keep driving it until you hear the knock it maybe to late for the crank . Don't worry about spinning them though you will hear them knock long before they spin.
Just an update and thanks to everyone making an effort to post and help me out.
The whirring noise was a huge scare, however it was only the bonnet hinge which is bizzare, hehe.. So im happy that it was that rather than something in the engine. Car has been driving fine and no abnormal knocks, so maybe I got away lucky...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
