MAKE AN OFFERS =)
OK I decided to sell my Enkei Wheels from my GTR.
Model NT03 White 17"x 9 Offset 15 with 245 x 45 tyres with 70% treads left on them. The colour is original and still have the Factory Stamps on back inside the wheels.They are still in Execellent condition. asking price $1550 firm quick sale. These babies are very light.
CAN POST ANYWHERE AT YOUR OWN EXPENSE
Got all 4 wheels washed and cleaned ready to go guys!!!!!!
These rims are from my GTR 32.
Tha factory labels is still on the back of the wheels!
mob 0402 876 050 andy
Edited by GTRBOYZ
https://www.sau.com.au/forums/topic/185721-sold-deleted-plz/
  • Replies 80
Posted Images
Let me know if your happy to split the dumps.
I want the dumps.
What size are they?
Thanks
They came with the Turbo's as a set otherwise it wont fit the standard dumps.
sorry I sell them together thanks =)
how laggy are is this setup? would it be good for approx 380-450hp?
Yea mate and they dont lag =)
on my motor it kick in at under 3k rpm..with a lil head work.
Should work fine on standard motor I say kick in at 3.5k rpm unlike the 2530 after 5k rpm.
It a really good street setup.
No worries, if someone takes the turbos, ill take the dumps.... at of course a reasonable price.
Thanks
hehehe sure mate if they dont mind then it all your.
...I need 1000cc Sard injectors.......=( and you got 800cc....Ratz
what size are these turbos? are then smaller or bigger then the HKS GT-SS? How old are they?
I bought this maybe 6months ago from a guy I know from work. I am not sure how long he had it for but the Turbo's still in very good condition and come with 1 Bar Actuators. I used it to run in my new motor for only 2000km and took them off since Iam going to go Single
now. Just taken them off 2days agoand yea they very similar to the GTSS.
Edited by GTRBOYZ
I got good new one of my GTR is about to be sold so I will go cheap on these baby HKS and Dumps =) to $1990 going quick guys. These babies will spool faster then N1 Turbo's.
Edited by GTRBOYZ
theyre quite similar to GT-SS but are plain bearing (from memory)
They are ball bearing according to the HKS chart -.-
http://www.hksusa.com/categories/more.asp?id=1092
Im keen on these turbos, but would like to see some pics first.. How much to post to Brissi?
-.- I do prefer pick up..so you can check the turbo yourself..seeing is believing. Depend on the price I might post it. The turbo is at the workshop now too.. I go find a digital camera and post it up tonite.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
