Hey all,
Last week my alarm decided to crack the sads with me. What happened was this.
With the Turbo Timer still counting down I arrived at work, closed the doors, got something out of the boot, closed it. Walked away from the car and went to arm it. The locking alert sound went but then it was followed by a second chirp. I went back to the car to see what was up. Turns out that I didnt close the drivers door properly, it was slightly ajar.
Problem is ever since, I cant lock and arm the car with the remote or have the motion sensor activate. The auto imobiliser still comes on after 30 seconds of shut down.
I can:
*Press the button on the remote, the light works
*lock the car with the original factory key (central locking)
*Disarm the car with the 4-digit override pin and start it
However I cannot:
*use the M80 remote to lock / unlock the doors
*use the M80 remote to arm the motion sensor
*use the M80 to disarm the motion sensor and imobiliser
Any ideas? It sure sucks atm having to do the 4-digit override with the alarm beeping every time I need to go somewhere. I dont feel comfortable knowing the motion sensor isnt working when I leave my car unlocked either. :domokun:
https://www.sau.com.au/forums/topic/186429-mongoose-m80-problem/
I have the same alarm.... although when that happens.. I just unlock it with the remote.... so unarmed... shut the door properly and rearm!
Sometimes I have buggered it up/confused it or something - so basically I had to unarm...shut the car down... turn the key to reds and turn off to reset the TT etc... and then lock again..
When you go to arm the car now... does it sound any warning signals such as a door is still open etc??? Possibly one of the sensors that determines that something is open are broken??? What happens if you shut the TT down straight away and try to arm? Does the alarm siren go off?? It should if it is still reading that a door is open and it isn't in the delayed TT mode
When I try to arm the car, it doesnt make any sound or signal.......doesnt matter if I try leave it running or off.
so have you lost the remote control side of it or does taht still work?
if so I'll send you the book (email pls) and you can rekey both remotes.
Cheers for the book mate, I managed to get the alarm into learning mode and tried to rekey the remote but still nothing.
Silly question but the batteries tend to die instantly in my M80... have you tried replacing them? Even though there will still be the LED flashing on the remote, there isn't enough power to transmit the signal....
All your problems you described also happen when the remote batteries need replacing, hence why I always have a spare battery on me!
Bingo! How easy is that.
I trusted the remote because the LED still flashed, next time I shouldnt assume :( . Spare remote works fine.
Cheers msnismo :(
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
