hey all these are left overs from my rb30det build up..
rb25de bottom end -
missing oil pump otherwise complete... i have heard they are the same as a rb25det just different compression ratio and does not have oil squirters, otherwise they are exactly the same.. this is in perfect condition internally, some dints in the sump.
$100
r32,s13,r33,r34 lockbars BRAND NEW (20 left)
$60 delivered express post
Datasystem EFC -
i believe it is a piggyback fuel computer but unsure.. it came out of an r33 i dont know how it works but is does work.. i dont know where the wires go either.. pics can be provided...
$50
RB20 head -
minus exhaust side, coilpacks and CAS
includes cams, cam gears, fuel rail, injectors, intake manifold, etc..
will even through in a bottom end but pm me about that.. come off a healthy engine the head is still attatched to the bottom end.
$200
all items in S.E. Subs of Melbourne
Edited by lwboosted
https://www.sau.com.au/forums/topic/186431-r3233-parts/
i have both types for sale.. r32/s13 and r33/34.. there are two different types and i have them both..
are the plugs you are talking about to block the hydrolics for r32/s13? if so no they dont i just used rubber hose when fitting mine.. works a treat..
r33's dont use hydrolics so there are definately no need for any plugs..
https://www.sau.com.au/forums/topic/186431-r3233-parts/#findComment-3379455
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
