woops sorry, didnt notice you have A31. no consult port on that like he said ^
u could replace ecu with r32 one and wire in a consult port (since car wont have one) but thats a bit of an effort
and powerfc doesnt support consult so if u were to do that but upgrade to powerfc, you'd lose it then anyway.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
