Hey guys, Ive got some gear up for grabs: I wont post pics cause people know what this stuff all looks like
Reason for sale? I went RB30 bottom end
Everything has come out of a working motor, reason for rebuild was pistons have damaged ringlands cause of a bad tune so it was causing a bit of blowby - couldve kept going but decided not to
RB26 05U block (bare block), still 86mm but needs to go 86.5 or 87mm - SOLD
2 x RB26 cranks (both R32 without extended collars, both will need machining and collars fitted) - $350 each ONE SOLD, One left to go
6 x RB26 stock rods with ARP bolts (i think ARP, ill check asap) and 6 x RB26 pistons - SOLD (came out of my motor which had a stock rebuild)
RB26 cam gears (stock) - $40 delivered to anywhere in oz
GTR turbos in average condition (no manifolds etc) - $180
All parts are pickup from Hurstville (which is south sydney) or ill post the smaller items at buyers expense (No COD)
PM or post up here
Cheers :P
https://www.sau.com.au/forums/topic/186685-gtr-parts-for-sale/
yes he still has the block.
Its still in back of my ute waiting for someone to eventually pick it up.
If you want it PM me and organise to come take it cause im sick of lugging it around!!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
