Hey people,
My r33 s2 has the following mods:
pod with box
3" turbo back exhaust
stock turbo @ 10psi
r34 gtt smic
SAFC
I got the car dyno tuned yesterday and it made 176kw. My tuner said it's still running fairly rich. He was unable to lean it out further as it started pinging. He thinks a possible cause for this is there may be oil in the cylinder (perhaps from a piston leak - hopefully that's not the case). Another possibility is that my stock ecu is advancing the timing too much causing it to ping, in which case i need to get a power fc (or a near non-existent sitc). I think the AFR is around 9 (very rich), and the safc shows a correction of only -2 across much of the high throttle (60%) and 0 across the entire low throttle (30%).
the pulley thing at the front of the engine (for manual timing adjustment) is set at "10", (whatever that means). This was set by my previous workshop. Current tuner did not change it, saying it shouldn't be any lower than that (down from 14 standard?).
First of all, can i just get a rough idea if that looks like a correct safc tune? i don't know but i was kind of expecting a little more variation, not just a flat -2 on high and a flat 0 on low. Also, how does the high/low throttle tune work? one set of corrections for above 60% and another set for above 30%? what about below 30? no correction?
secondly, shouldn't all series 2 r33 ecu's be the same? are some known to have more aggressive timing than others?
and finally, is 176 reasonable for my level of mods? i was expecting something closer to 190, but the car is still running very rich, so that sort of explains it.
Also, i *sometimes* feel a bit of a flat spot, which is followed by a slightly weaker pull. This may or may not be related to the above issues. However this is not evident on the dyno graph.
Thanks for your time, guys.
Edited by ak_stylez
https://www.sau.com.au/forums/topic/186918-safc-tune-timing-or-piston-leak/
yeah i do but no scanner.
Boost jumps up to 9 psi at about 2500 rpm, then creeps up to 10 by 4000rpm where its fairly steady til red line.
the power curve is fairly straight with a few bumps here and there and max power is just after 6 grand.
does that help??
for starters the pulley on the front of you car for the manual timing, or the CAS should be set at 15 degrees, 10 is to low.
the throttle set points with your settings of low 30% and high 60% are: low throttle map is 0% to 30%, and high throttle map is 60% to 100%. everything between 30% and 60% throttle are just interpolated. the tune that you are describing doesn't sound like a real tune at all. -2% of the high map is bugger all and with your mods you probably don't need to trim or add anything on the low throttle map. the std ecu's like to rich out under full throttle and boost.
i'd say get your base timing set to the correct setting, 15 degrees, and you should be able to trim much more off the high map without getting pinging.
hmm. so, advanced timing makes the valves open sooner, right? this means air enters the cylinder earlier, causing the mixture to detonate sooner?
so if the base timing is adjusted back to 15 wouldn't that make the engine ping more? or is my logic flawed?
is knocking a result of advanced or retarded timing (or either).
edit: or does the CAS change ignition timing? in which case I can see that retarded timing would cause detonation because the spark is not igniting soon enough.
Edited by ak_stylez
no no no..... the cas adjusts your base ignition timing, your thinking of you valve timing. your valves still open and close at the same time, with the cas you can adjust when the ignition/spark is fired.
so when you retard your base ignition timing you infact delay your spark. buy advancing it you make it spark earlier. knock will occur if your timing is too far advanced or retarded too much.
ahh now i see. so really my tuner should have advanced the timing when it started pinging. But I'm wondering why it was retarded so much to begin with.
I'll give him a call tomorrow. Thanks Josh, you've been most helpful :down:
Hey,
well I spoke to my tuner today, he says that when he first started he put the CAS to 15 but it was pinging, so he put it back down to 10. Any ideas as to why we were not able to lean it out much? the AFR is about 10 right now. I'm thinking power fc will solve my problem.
Also got it compression tested with all cylinders coming in between 150 - 160 which is quite healthy so we can rule out any sort of piston leak.
one thing to take into account is that as you manipulate the afm signal with the safc to trick the ecu in thinking its not getting as much air so it injects less fuel is that, when you tell the ecu its got less air it also doesn't add as much timing to the ignition map. the more you bend the signal to remove fuel the more retarded the ecu timing becomes from what it should be and then you get pinging.
with the safc you need to find the balance.
and start looking at other things, i just saw in your first post that you said you still have a side mount intercooler. i don't know how good the smic are but is it posible that it isn't cooling the air enough? the hot air would ignite the fuel before the spark and you'd get knock (ping). maybe? just a thought.
hmm... perhaps. But i'm only running 10psi, plus it is an r34 smic (which is slightly bigger than the standard 33smic) and rated at up to ~220kw so I thought it'd be fine for as long as I plan on keeping my stock turbo.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
