Hi guys,
Need to get rid of some items due to finances as i need to get some new tyres.
All items priced for a quick sale:
2) Sets of MTX Thunderdome Coaxial 6.5" Speakers: BOUGHT: $159ea SELL: $85ea
EDIT: SPEAKERS ARE BRAND NEW STILL IN BOX UNUSED
Frequency Response: 48hz-20khz
Impedance: 4 Ohms
Impedance Rating: 4
Included In Box: Manual
Mid Range Size: No
Mid Range Style: Info Not Available
Mounting Depth: 2 1/16"
Power Handling: 120 Watts
Product Dimensions: 22.0(W) x 10.5(H) x 42.0(D) cm
Product Weight: 2.9 kg
Recommended Power Range: 120 Watts
Sensitivity: 92Db
Speaker Size: 6 1/2"
Speaker Type: 2-Way
Pictures for illustration purposes.
Apexi Power Intake Filter (Panel Style) PRICE: $30
Apexi Part: 503-N101
Greddy Boost Guage - Electronic Warning Series w/- Recall BOUGHT: $390 PRICE: $160
Comes with wiring harness, boost sensor and computer.
Still in car. Glows green. Picture for illistration purposes. Colour White
Gizzmo Intelligent Boost Controller (Used) SELL: $190
Comes with boost solenoid and wiring harness. Still in Car. Picture for illistration purposes.
Four Boost Memories
Adjustable up to 2bar (29lb)
Fast RISC Processor Technology
Real Time Digital Boost Gauge
Extruded Alloy case
Simple 2-wire installation
Suits internal or External Wastegates Comes complete with all Hoses and Fitting
The Gizzmo IBC (Intelligent Boost Controller) represents the ultimate in Accurate, Simple to operate, and Easy to install Computerised Boost Controller.
Because all the thinking is done inside the IBC, you will not require an Engineering Degree to operate or fit it.
With the Gizzmo IBC’S precision 29Lb MAP sensor, High Speed RISC processor and Powerful MOSFET solenoid driver, and the fastest, most powerful solenoid you can be assured that your Gizzmo IBC has the Quality, Resolution and Accuracy that you need for your Turbocharged vehicle.
Additional Info --> Click Here
Prices are ONO...
Pickup from Parramatta Area prefered
If interested please pm, sms or call on 0448 944 096
Cheers all
-Brenton
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
