Car: 1992 Nissan s13 Silvia
Trans: manual
Engine: Rb20det (from r32 gtst)
Contact: Brendon 0412 809 376
Pictures: coming...
Roadworthy: yes
ENGINE
New Battery
Pod Filter
New AFM
Decarboned Plenum
3 Inch Turbo back exhaust, 2 inch Twin pipes from the diff back..SOUNDS HOTNESS.
Front mount Intercooler (600x300x76)
GTR Oil Pump
GTR Water Pump
Trust Multilayer Metal Headgasket
Rb25 Turbo Running 7psi
Bosch 040 Fuel Pump
Sard Fuel Pressure Reg
Cleaned Standard Injectors
NGK iridium Spark Plugs
Power Steering Cooler
Oil Catch Can
R32 Radiator (serviced with new top tank)
Thermo fan
Wiring has been redone neatly! looks factory.
Mod Plated for the conversion
SUSPENSION AND HANDLING
Jic Coilovers
Cusco Camber Tops
Rear Adjustable Strut Brace
Alloy Cradle Bushes
Alloy Steering Bush
Rose Jointed adjustable tie rod ends
R32 Tie Rods
DRIVELINE
R32 Gtst Gearbox
Short Shifter
Heavy Duty Exedy Clutch
Custom Gearbox Mount
Standard Lsd
INTERIOR
Cd player + 6 inch two ways
Water temp gauge
Oil Pressure gauge (sender not fitted but supplied)
Volts gauge
Boost gauge
Steering Wheel
Gear Knob
Interior is complete and in good condition, the dash has seen better days though it has cracks.
EXTERIOR
17 Inch Steer Rims
Sr Stocko Rears
Nismo Grill
511DIN number plates
More recent pics coming soon, these are a few months old.
Due to losing my licence i deregistered the car to pay fines...im looking to build a budget track only car now,
will accept r31 manual sedan as part payment, will also drop the price without coilovers and number plates.
Im looking for 11k As is with everything included.
Edited by frost_e
https://www.sau.com.au/forums/topic/187053-rb20-s13511din/
  • 3 weeks later...
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
