well if its a 1989 R31 GTS-R RB20 and a 1989 R32 GTSt RB20 then yes, one is a NICS and the other is an ECCS.
Sorry to hijack!
But with regards from the red to silvertop... will the redtop ECU still talk to the silvertop enough to drive it? Im throwing a silvertop in the 200ZR this weekend but didn't even think about the difference between the NICS & ECCS! :(
Not quite sure, ask on the R31 forums or maybe someone on here with more knowledge on the older RB20's could tell you definitively. They could have different ECU pinouts and looms. I know the processors in the ECU's themselves are different as are the IO interface chipset... but they could have standardised input/output.
There is:
Red Top NICS (Early R31)
Red Top ECCS (Late R31)
Silver Top ECCS (R32)
I believe that they're all incompatible as far as ECU's go. I doubt even if the Red top ECCS ECU could work the Silver top properly (which I thought it couldn't), the NICS ECU definately couldn't. Besides from memory, the money to spend on getting the silvertop ECU you'll quickly save with the (far) better fuel economy.
The R31 forums are definately the place to get a definate answer though.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
