i have notice one more thing with the car the idle is very high sits at about 900 to 1000 rpm, i tried to reset it to a lower figure but it still sits up at 900 to 1000 rpm could this be a connected problem?
Im only new to the scene and dont know too much, I have an r32 GTR, it also idles high, it is caused from a air leak in one of the vacum lines, so I would check them all carefully first. If you have the stock cat in it, you should be able to get 10-20 rwkw from fitting a high flow metal cat. I had the same problem in my GTR, when I got it and had it tuned, it really died off up top, I changed the cat and it made a huge difference, 15awkw. Yours is a rwd so might make abit more if you change it but you'll still fall short of 300rwkw, How good is the tuner you took it to? A mate of mine took his r33 to a tuner and got 213awkw@21 pound boost, he wasn't happy with the result, I took him to the boys at CRD (Croyden Racing development) they charge abit but do a fantastic job, they got him 260awkw on the same boost. The car was a jet when it left there. So tuning has alot to do with it. I would say do your research and find a good tuner, good luck!!
thanks mte i might take it down to a different tuner see what they say regarding the setup. cheers
Skyhy,
I recently had mine tuned up and came across the same funny little dips. As we wound the boost up those dips got much worse and killed power.
Another thing noted was as the dips got worse a lot of unburnt fuel was floating around which instantly made me start thinking ignition.
At the same time the clutch began slipping 'slightly' which later got much worse.
I now have a good clutch in the car its amazing how more power wasn't getting to the back wheels.
I've got a few things that are to be sorted.
1. 450x280x90 FMIC with 2.25" inlet outlets.. Tad on the small side for the power So decent fmic
2. Spark plugs came out looking a tad hot. So NGK 7's in they go
3. I've been told to try NGK R5671A-7 as they position the spark in a slightly different position which prevents the spark being blown out. Apparently.
Fingers crossed the little dips disappear. :)
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
