For Sale:
L-shaped five seater with chase in suade. Colour is cream. It is in excellent condition, was purchased on the 22/08/06 with 5 years warranty and 5 year fabric protection. Measurements are: 2.9m X 2.1m X 0.9m
I'll post a pic up in the next couple of days.
Asking price: $900 ono
Pm me if you're interested
https://www.sau.com.au/forums/topic/187520-for-sale/
For Sale:
I'm about a day late, I just bought a lounge suite from Nick Scali, go the sales!
https://www.sau.com.au/forums/topic/187520-for-sale/#findComment-3385860
arent Nick Scali always having a sale?? :)
i have a friend that might have been interested a week or two ago but she just bought the bargain $3K fantastic furniture pack so prolly not anymore...
me and veilside are really no help at all are we... haha
oh well free bump!
https://www.sau.com.au/forums/topic/187520-for-sale/#findComment-3386326
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
