Hey kids,
I got a MASSIVVEEEE stack of rubber here, as you can see
I need it all gone
I dont want it
I dont need it
SO WHO WANTS IT ALL?
$500 for all this.. come and take it off me.. get your truck/ute/ trailer and take it all
4x 255/55/18 Goodyear Wrangler HP– nice even wear on all four of them, about 40% left aswell $200
4x 205/60/16 Michelin Vivacy – 50% left, all even wear $150[sOLD
4x 205/40/17 Nankang Ultra Sport NS-II – 2 have around 20% left, other 2 have 55%, even wear $150
4x 225/55/17 Bridgestone Turanza ER30 - about 25-30% left on them, all even wear $120
3x 205/55/16 Bridgestone Turanza - 50% left on all three of them $200
3x 185/55/15 Bridgestone Potenza RE040– about 50% left on him $200
3x 215/60/15 Brisgestone RE711– 50% all round, good even wear, very aggressive looking tyre $150
2x 235/40/18 Fullrun HP199 – some slight camber wear, about half way through – 50% left $150
2x 235/45/17 Nankang Ultra Sport NS-II – got some camber wear on them, about 35% left $125
2x 205/45/17 Silverstone – probably best for track events as they have some camber wear $50
2x 235/45/17 Khumo Ecsta – some camber wear on the inside $120
2x 205/40/17 Silverstone FTZ Sport– one has some camber wear and the other has about 80% $120
2x 255/55/17 Bridgestone Turanza ER30– about 40% left on it with even wear $80
2x 205/55/16 Bridgestone Turanza ER30– one has about 80-90% left and the other about 60% left $120
2x 225/50/16 Firehawk Wideoval - aggressive looking tyre, got 40-45% with even wear all round $100
2x 225/55/16 Khumo Ecsta – one of them has some camber wear, the other about 60% left on it $75
2x 195/65/14 Barum Bavavis – best for scrubbing out for track & cruise events $20
2x 185/65/14 Yokohama S220 – 20-25% left on them with all even wear $20
2x 155/65/14 Toyo J36 - one of them is worn and the other has 40%, good for burnouts $20
1x 215/35/18 Toyo Proxies F24– about 70% left on it $ 50
1X 205/45/17 Nexan N3000 – he has about 40% left on him $50
1x 215/45/17 Bridgestone Potenza RE040 about 25% left on him $45
1x 205/60/16 Bridgestone GIII– got about 45% left with even wear $50
1x 195/50/15 Potenza GIII– 45-50% left on it, great tyre with awesome performance and reviews $50
BRISBANE
PM PM PM PM PM
0420 926 501 < TEXT/SMS ONLY!!
DAN> Fs: Qld - Rubber Rubber And More Rubber
I'm after 18s 235/35 x4 and/or 245/35 x 4 - if you could send me a PM with a price, that'd be good thanks.
Edited by KustomR33
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
