  • Replies 285
looking forward to the report. how did it fit? i assume you have a 33? did you keep all the factory shrouds? 60% more is pretty good.
Yeah.fitting it was as easy as taking the old one out and putting in the new one.
a few things to mention though:-
*The radiator must be earthed by an earthing strap/cable.if you want the all things metal in the cooling system to live.it has to do with electralosys.
*You will need to go to supercheap and buy 3 copper washers for the temp sensor.
I still havent driven the car as of yet.hopefully by thursday.
just make one.
ie: a cable from the radiator to the chassie. metal to metal.
it really has to do with positive energy build up in the aluminium rad. seen as though it is mounted on rubber. it kind of acts like a storage device for positively charged energy to sit in the system.hence the earthing will allow that energy a place to escape.
ive been told that if it isnt done, within a few months or so the rad can be corroded inside.
I as accuratly as i could guestimated the capacity of the new radiator and therefore the rest of the system as well. To give me an idea on the ammount of coolant that i need to add. For my R33gtst.
New Radiator = 3.72L capacity = a 59% increace in radiator capacity.
system with new radiator = 10.02L Total system capacity.
Old Radiator = 2.2L capacity.
system with old radiator = 8.5L Total system capacity.
Hope that helps some people out. :spank:
All good
I just took the car for a run, with the radiator installed. She runs cool. It took about 4 times longer for the thermostat to open. No shit, i thought i did somthing wrong but it was all good. The car was running at thermostat opening temps when i was up and running. And diddnt budge. Though it is a cool night with normal driving.
I want to see how it performs out on the track most of all.
you still got the shroud on? take some pics!
I will take pics of it later.
The thermostat opens a little later than usual but it isnt taking as long as it did last night. I think it was a topping up issue and the fact that it had just rained so it was a little cold. Works a treat though.
I lost the dimensions that i took of the radiator somewhere. But i think it is the same height. Just thicker. Put it this way. There is no clearance issues with the bonnet.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
