1993 R32 gtst type M
Colour: Black with Blue perl
MANUAL
Mods:
HKS dragger exhaust with twin tips
Hks pod
Full after market bodykit
Trimmed door cards
JVC headunit and JBL speakers
Splitfire boost gauge
17x8 Drifteks at the front
17x9 Drifteks at the rear
190,000 kms
looking for around $12,000 ono
Car is in great condition inside but has some minor damage on the rear quarter panel. Was run into by my cousins push bike at a family bbq and has a nasty scratch . I have been quoted roughly $500 to fix so I have taken this off the asking price. Unfortunatley i dont have a picture of it yet.
Has a great deal of work done on it over the past couple months as it has had some minor problems. So it will be very relaiable for the new owner. I have also put four brand new high quallity tyres on it too and i have barely had time to drive it anywhere so they are like new. I have receipts for almost all the work I have had done to the car. The previous owner had the car dynoed at 157kw at the rear wheels
I am selling the car as I will be joining the RAAF and also need deposit for the bank as I have put a contract on a unit. I am looking for a quick sale so i have priced it accordingly.
REGO and RWC
I'm located in Nerang, If you have any any questions please feel free to give me a ring or send me a msg
on 0413670323
Thanks Josh
https://www.sau.com.au/forums/topic/187938-r32-gts-t-for-sale/
  • 3 weeks later...
  • 4 weeks later...
  • 4 weeks later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
