I've got my turbotech boost controller set to 10psi, and it worked great for about a week. Now when accelerating past 4,500rpm boost drops noticeably to about 5psi (although the gauge shows 5psi it doesn't even feel like it's making that much boost). It's a really noticeable drop off in power.
I took it to the mechanics the other week and wouldn't you know it, the car worked fine when I was there.. but the problem is back now. Any suggestions of where to look? Will it just be a leak in the vacuum line?
Problems driving me nuts.. boost seems to work and pull fine prior to hitting those higher revs, like the additional pressure is causing a leak???
https://www.sau.com.au/forums/topic/188252-losing-boost-after-4500-rpm/
When I removed my plenum to inlet manifold gasket I noticed it had been leaking.
When refitting inlet manifold/plenum/throttle body gaskets I gave them a spray with Hylomar just incase.
Using Hylomar also helps should you have to pull it apart again; it prevents gaskets ripping etc so you can save a few $$ and reuse. :(
could you haer a sucking sound coming from the plenum when it was leaking.
I can hear a sucking or hissing type sound coming from my plenum at the moment. Didn't know what it was though, just thought it may have been normal. Guess my plenum is leaking then?
Edited by Simmo1985
Would a leaking plenum cause any other problems? Just trying to figure out if that is in fact the problem, because the car drives perfectly normal otherwise.
Edited by Simmo1985
No strange sucking noises apart from the usual idle sssshhh noise :)
I think mine was only leaking on boost as it didn't cause any strange idle issues or afm readings.
i got this same problem, i hear a loud hissing like noise come from the plenum at high boost and notice my PSI drop from 20 to 15.. I still haven't got around to pulling the plenum apart and changing the gasket, but i'm pretty sure thats the problem..
  • 3 months later...
I think I have a similar problem. Had it tuned running 18psi no worries but after a week of driving it doesn't seem to hold boost. After 6000rpm the boost drops from 18psi to about 5psi. I can't hear any strange noises though..
I dont think its the inlet sucking closed as I placed a metal pipe in part of it. It looks a little weepy round the plenum gasket. Hopefully thats it..
ANYone got the part no. for R33gtst?
Edited by benl1981
The mechanic reckons I should just change the gasket without even running it on the dyno. They reckon theyve seen a lot of this on the rb25s. It isn't always that easy to hear apparently - and under load there is so much air floating around there with the fan going etc..
Will have a bit more of a check myself..
Nissan want $85 for one! There was a little oil residue around the join. We cleaned this off but there isn't really much coming back. Might run it up onto boost a few times and check again. I did a few 0-100km/h runs the other day which may have blown it apart..
Edited by benl1981
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
