  • Replies 58
Posted Images
don't be a fool man
haven't you been listening @ all
R12 is for R12 systems
R134a is for R134a systems
DONT mix the two or your compressor wont like it
my mate also says you cant get R12 anymore and its been like that for years so if there saying its R12 its prolly one of the substitutes
if you want to waste $170 on getting that then go right ahead but i did tell you earlier my mate can do it for $50
Edited by Madaz
hrmm the place you told me, down lonsdale. alright madaz can u ask ur mate if he can regas mine than and when and where could he do it. thanks
ok mate, just rang him he said by next weekend as hes on holidays and will go into work next week and get some gas
If you have r12 which is an old gas you will need to swap it over to the new gas R134a
and if you need a regas you have a leak.
so you need to pump some nitro through it to see where it is. most of the time its the o rings on the flair nuts so just tighten so of the connections and hose fittings up.
To see if you need some refrigerant check the sight glass on the silver tank looking thing [drier] and see if its got a full charge of liquid do this while the car is running and the AC is on. also check to see if your condenser fan kicks in.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
