i like skylines wooooo
lol, i am never attempting to put an aftermarket rear bar on again.
thing p*ss*s me off so much, and now i cant get my bloody side pods bak on.
who wants to spray my rear bar midnight blue and install it for me??????
what brand is it sometimes u get what u pay for with the cheaper ones if its a good brand u should have minimal problems >_<
Just bitching about my unproductive day. Me and Jenkies decide today is that day to put my new intercooler and dump pipe on. Front bar comes off easy as, no problems. Bit of trouble trying to get the stock cooler off.
Decide to have a break before we take it off. glance over to my intercooler box, peel back a bit of packing tape and see "R33 Kit". well now, thats not what i ordered?
so anyway, put everything back together, make sure all bolts are on. ok time for dump pipe.
or, not.
nuts have seized, no chance in hell of getting them off.
so for just under 5 hours of labour, we accomplised:
- found one nut on the cat was really loose, tightened.
- removed thermo fan so cooler core will fit.
lesson for today. pay someone to do it for you.
I'm pretty sure that R32/33/34 intercooler kits are interchangeable as most of them use the factory hot pipe side of the piping and for the cold side you have to cut a hole so there won't be a problem there with lining up as well. Better pull it all back off again.
Might just take it to an exhaust shop and get them to fit it for me. That way i know if they snap a bolt, they fix it. I on the otehr hand, dont have the tools to fix anything major.
no dont coz they will make u pay for the snapped stud.
i have tried that wen i wanted my screamer on and they said nothing about it n i mentioned that sum of the nuts mite be tight n they said if it snaps it not there fault and u have to pay to get it removed.
and if nothing is mentioned about it they will still make u pay! it sucks but they class it as not there fault because they are just doing wat you asked them to do.
Yeah but the mounting brackets that were supplied wont fit.
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
