AE86DC or rollaclub are your friends.... Mine has a very basic setup... ADM sprinter front end/brakes, TRD struts, AJPS springs, modded stock R32 struts and springs cut in half, LSD (locked standard diff) Corona Lower control arms (15mm wider track, 2.5 deg camber) and new bushing in the rear end. Could prolly have a similar setup for around $1k installed..... Buy a Keto for $500, you're ready to go.
Im changing the whole setup soon....
JDM twin pot calipers and vented rotors
AJPS front coilovers w/ Bilstein adj struts, 7kg springs, Cusco camber tops,
Bilstein rear struts and AJPS 5kg springs
AJPS 35mm RCA's
Whiteline front and rear swaybars
Noltec panhard rod
Cusco Tower bar and tension rods
AE86 power steering arms for more lock.
T18 diff locked
Not cheap (Bout $2800 - $3K all up) but it'll probably handle/slide better than my R31.... all it needs is a SR20DE in it and she's ready to go...
You can also fit an entire S13 front end, using RA40 celica/910 bluebird parts.... good if you can get S13 coilovers cheap 2nd hand....
they are essentially a AE86 without takumi tax.....
Oh, ordered my new wheels today... 17 x 9 and 18 x 9.5 drifteks in white for the 31, and 15 x 8 -4 superlights in platinum silver for the '70 .... gonna look hot.
nah, havent changed my mind.... just happened to be what I wrote.... :laughing-smiley-014: 4AGE, SR20DE, N/A 13B, CA18DET... ANY of them would be spastic in a KE70
Stiill trying to sus out everything for the conversion, It's a lot more difficult than a standard 16V RWD 4AGE......
Like I said, let me know when he gets back from holidays...
And that 1st/2nd video.... those cars are exact doubles of mine LOL......
Edited by R31 drift pig
anyone know if u can get a permit to drive a defected car once it has been booked into regency and mods removed?
Yeah, go to a police station and get a clearance.... they'll come out, have a quick sus, and sign the paperwork that you can drive the car until regency or your rego runs out.
i started this project like 6-9 months ago using what i had lying about ive spent 2500 on it so far .
its ready to be started just ive given up on the car.. as my plans have changed
like fixing my r31 with rb30det and getting my r31 with sr20det going ...
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
