found what killed my alternator.
power steering fluid leaked down from my power steering resevoir and into my alternator. big of a bugger as now i have to reseal my power steering, but at least i know what killed it.
its still at Mallala. Its running in the afternoon i believe at some point. All the details are on NS but its having downtime at the moment so when its back up ill find the details and post them up.
yeah just checked out the shannons national webpage
http://www.thenationals.com.au/categories.asp
not to shabby collection of cars, dosnt say how much the gate entry is though :)
thats for people to find out at the gate n say well its too late to turn back home now.
THIS IS FOR SUNDAY
SHANNONS NATIONALS 2008
Round 3 Mallala SUNDAY 18 May
Time Description Category Duration
700 Gates Open
820 Warm Up Tankworld Supertrucks 15 mins
840 Race 2 Porsche GT3 Cup Challenge 12 laps
910 Race 2 Shannons V8 Touring Cars 12 laps
940 Race 1 Tankworld Supertrucks 7 laps
1005 Heats Super 8 Drift 4 x 2 Battles 20 mins
1030 Race 4 Ironfarmers HQ National Series 6 laps
1055 Race 2 Supertrucks - Reverse Grid 7 laps
Clem Smith Cup
1115 Race 2 Kerrick Sports Sedan Series 15 Laps
1150 PODIUM: Clem Smith Cup 10 mins
1200 Race 1 Kumho Tyres Aust. F3 Championship 14 laps
1230 Race 3 Shannons V8 Touring Cars 12 laps
PODIUM: Formula 3
1300 Race 3 Porsche GT3 Cup Challenge 12 laps
PODIUM: V8 Touring Cars
1330 Race 3 Tankworld Supertrucks 7 laps
1355 Semi Finals Super 8 Drift 2 x 2 Battles 10 mins
PODIUM: Porsche GT3 Cup
1410 Race 5 Ironfarmers HQ National Series 12 laps
1440 Race 3 Tankworld Supertruck Co-drivers 7 laps
1505 Race 3 Kerrick Sports Sedan Series 10 laps
PODIUM: HQRA
1535 Final Super 8 Drift 10 mins
1550 Race 2 Kumho Tyres Aust. F3 Championship 14 laps
PODIUM: Sports Sedans
1620 Race 4 Tankworld Supertruck Superprix 10 laps
1650 Team Super 8 Drift - Quad Drift 15 mins
PODIUM: Supertrucks
just put a thread in events for the super 8 drift. All details, timetables for both days etc is all there.
http://www.skylinesaustralia.com/forums/Su...on-t219018.html
im keen to go check out some other forms of racing so will try and get the weekend off again i think lol.
watch for the current sports sedan lap record to fall with that killer Audi, Corvettes, jag and of course the Alfa all running - would be even better if the DB9 was ready to run this weekend
sports sedan entry list (this is the real V8 supercar series here)
http://www.sportssedans.com.au/images/mallala.pdf
Dean Camm's vette is around 5 seconds faster than the leading V8 supercars around Phillip Island and the Audi is around 4 seconds faster around sandown (the only race i have ever seen a car get a 8 second lead on the first lap!)
the porsche challenge will have a few cars - its the first round of this series so don't expect too much from it. Still will have some nice cars 996cup - RSR + older non turbo porsche's
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
