Flick - Do you have an RCD (Safety Switch) on your house? If all the power went off when you got the shock I would say you do, otherwise get one installed ASAP! And if you got the full 240V (iron may be rated to 260V, but Australian system is 240V), then yes you would have got the cramps as 240V contracts your muscles, meaning you wont let go of whatever is shocking you.. its actually the most un-safe voltage in the world :P
Higher voltages throw you off, lower voltages dont contract your muscles... stupid Brits and their 240V system!! LOL
(Note - Qualified Sparky here, cash jobs on weekends :( )
yeah we got a safety switch. Handy thing that..
Didnt get cramps or such, just scared the crap out of me more than anything, was quite a loud zap. Heart was probly racing cos i got so freaked out lol.
Such a girl tho... wasnt worried bout the fact i just zapped myself.. was more upset i couldnt straighten my hair lol
hahahahahahaahahaha.
how did ya manage to zap urself though??
i cant figure it out,
my uncle has an electric fence though around his 1 acre dog compound in the country and he has 2 alaskan malamutes and one day one of em was leaning on the fence and not getting zapped and i was thinking sweet it must be off.
go to climb through it and yeh dumbest thing i have ever done.
my hair was sticking up for about an hour or so afterwards. was best adrenilin rush ive ever had lol
Yeah me too Luke, was gonna buy a 044 and do an intank setup but I like the ease of the Nismo. I know it costs more but hey...
that's why i went nismo! 044/040 is still a fairly easy install in a 33.
Quick Q: would a 910 be just as good as the 044?
910 and a 040 are pretty much the same thing with a different fitting i think, an 044 is an external and bigger which isnt necessary for anything below 300rwkw
I am thinking of getting bosch 044 pump but dont know how to install it....might require ur help if your willing to
040 is designed to be intank, 044 is designed to be external, some people put the 044 inside the tank but dont realise the o rings etc aren't meant to be submerged inside the tank. 040 is the largest intake you can get and will supply more than enough fuel for alot of people.
taken from sliding performance
Nismo In Tank Direct Replacement Fuel Pumps
R32 GTR Model Number : 17042-RR581, $499 Delivered
R33 GTR Model Number : 17042-RR596, $499 Delivered
R34 GTR Model Number : 17042-RRR46, $499 Delivered
R32 GTST Model Number : 17042-RRS31, $429 Delivered
R33 GTST Model Number : 17042-RRS41, $429 Delivered
R34 GTT Model Number : 17042-RRS51, $429 Delivered
S13 Silvia Model Number : 17042-RRS31, $429 Delivered
S13 180SX Model Number : 17042-RRS31, $429 Delivered
S14 Silvia Model Number : 17042-RRS41, $429 Delivered
S15 Silvia Model Number : 17042-RRS51, $429 Delivered
Price and delivery from Australia All fuel pumps delivered in 2-4 Days
GTR a bit more expensive heslo i see
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
