Just on these Mobile Phone in Cars law thing, is it still illegal to use your phone to call someone if you use Loudspeaker?
As far as I know, they've banned the use of mobile phones COMPLETELY in cars ... hands free or not.
Mind you in the past week, I've seen countless cops chatting away on their phones. :down: I even gave one cop the "hang up" hand signal. He just glared at me as he drove off.
So who's policing the police? :(
if the phone is sitting somewhere and your not holding it then i dont see why you cant use it, same thing.
its fine to talk to 4 other passengers however, eat a whopper or sip on a drink, but cant talk on a phone, who the f*k is thinking up these stupid f*kn laws, id like to meet them
Edited by Ryanrb25
do you drive the silver one much ruby?
Gee id love to be you in the morning. "hmm what should i drive today, the black or silver stag? or maybe ill ride one of my bikes.."
The weather has been nice enough to get out on my bikes. :down: Though I do drive the black Stag more often, closely followed by the silver Stag in useage. Although my GF pretty much decides what I'm driving/riding for the day: "Baby, can I drive the black stag tomorrow and you take Cam to school on the Brutale?" :(
its prob like that powerball ad....with that dude and his miss have all those cars and cant deciede what they wanna drive in
I'm not that bad! :(
Tell me about it on sat night i was pulled over and told i dont have a drivers licence and havent since dec last year and the cop asked for my mobile number and said he would sort it out and call me then mon night i have a cop sitting a few doors down from me
The same fools sticking speed cameras up everywhere (in "black spots" *wank-wank*) and deciding what motor events to hit with defect stations.
:down:
After alot of thinking today im not putting my gt35/40r on my rb25 for a while until the car is run in and iv hade fun without worrying about the law. Im thinking of getting my my rb25 turbo high flowed just untill i deside to put the 35/40r on, so what is the cost invold and can i expect around 250kw?
well insurance.. petrol.. it just keeps adding up! Want to save money cos atm i have ZILCH savings which sucks, cos it all goes on keeping the car going..
yeh im trying to save for a house deposit, just as an investment. impossible :D
so, im considering selling my 32 .. Want to be out of debt and be able to save for a house etc.
Im sad just thinking bout it lol
Oh, oh....spill it Flick......is there something you need to announce Luke.....we have ways of making you talk!!! :D:P
Should be able to do that, just cant have ya phone in your hand.
And on the police using their phones, i've seen them doing shit on their computers while driving. Seems police and taxi drivers pretty much do what they want, but hey, who's gunna stop them...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
