congrats on the sale of the car flick, does that mean you guys will be repping shepparton in the falcoooon?
on another note ive got a business id like to plug for their awesome service. took my radiator to get pressure tested and flushed today, went to Parkside Radiators (also trade as Edwardstown Radiators) at Melrose Park. The guy tested it then and there, showed me where the 2 leaks were, explained what he would need to do to fix, told me not to be too fussed about a couple of bent fins (from fan contact at some point) as it hasnt damaged it. I told him it wasnt a rush to fix it, and that id pick it up same time next week, but he still offered to fix it tonight and have it ready for pickup tomorrow. The clincher: For the pressure test, re-soldering around the top tank outlet, fixing the leak in one of the tubes, replacing the "tap" (which id broken off ages ago and let it weep a lil bit), and giving it a reverse flush, its costing me a grand total of $70
+1 to them
Parkside Radiators
7 Manfull St Melrose Park
lol ryan
nah, need a proper cat
617 is far better than the current 200cfm item :D
definately know, by changing this, easy 200kw tune
last night had the attessa system working , lol
boosts well, bit soft in first, but second and third pull hard
IMO around 200ish atw is enough for the street, always been my goal.
sleeper wagon, nothing outstanding to look at (bar being a Stagea !), but streeter-eater deap down
:banana:
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
