Nice... 250rwkw odd is definitely a lot of fun. :whistling:
I'm in the process of dropping a set of cams 265/265 9mm in to mine at the moment then off to boostworx for another tune with a tad more boost. I'll keep cranking boost in to it until it stops making power. :D
Fingers crossed I can crack 300rwkw on the std exhaust manifold.
Last time I was on the dyno it made ~260-268rwkw on 1bar with std cams; hopefully I see 25-30rwkw increase with the cams on the same boost.
how much hp left in that turbo Darren and is 17 psi still safe on standard head gasket or has he gone for reliability and safe tune, was that a slide high flow
ahhhhh not sure hp wise, but id say it might have about another 20 more killa wasps in it, if he's only on 16psi then in sure it could boost upto 18 easy and be up around the 260-270, but then yeh the turbo will be maxin!!
Nah its a ATS Hiflow and yeh still on standard head gasket!!
Anyone had a day at work that just did your head in?
This bloke had one of those day's;
What a f**king looney! :laughing-smiley-014:
Felt sorry for the female co-worker who copped the monitor in her face. :D
Everyone must not like working there, if they were happy to stand around and let him trash the place.
Hope your mum is feeling better now, look after her good we only get one
Nah Steve, mother has epilepsy and she had a bad night last night with a few fits during the night, as a result, I got 9/10ths of bugger all sleep
i was sick mon tue with the ful or something, got to work yesterday still sick as and got reemed for having 2 days off even tho i had sick cert from dr and told him i was that sick i couldnt even get out of bed to take locky to school and that chad came over with some dinner for me. :D
Then today i get a email BC to me this morning saying he wont be in as his son is sick and his wife is at work night shift and his son cant go to day care, his son goes to his aunty's not day care
seriously WTF is anyone a boss on here what do you think :D
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
