bord bord bord bord bord bord dmdesljksxdfz,mnbzds/lfgh bord but........................... i brought some new dior last night yay ................................thats all bord bord "sigh as i bang my head"
Just got the car on the dyno, still need to put gtr injectors in and get jeff to remap. Does any1 know if this is ok??
Looks good.. ~7 years ago mine made 164rwkw on 15psi with 12:1 afr's.
Went damn well 0-100 in low 5secs and 0-180ish in high 13's to flat 14's.
thats great
are you coming on the cruise havent seen you in ages
small bearded dragon
large tree
impressive written assignment
large
legs
farting noises
death
arm wrestle
I wrestled a bear once
small ant
rather cute lady
beer
carlton dry fusion
cutie bubby.
booooooogy boooooooogy bum bum
pretty impressive! got a friend who has an r32 as well with a high flowed turbo! pushed out decent power, like over 190kw or so! but it lagged out like crazy, didn't see any power till almost 5000rpm!
thats great
Unfortunately not; the car is laid up in the drive way. Fitting a set of cams tomorrow; replacing the steering rack after work during the week; then in for a tune so I will miss the cruise.
I had a larger turbo on the rb20det for a while; the following week I dropped the stocker back on and crammed 1bar back in to it as the larger turbo was gutless through first and was slower for general street duties than the highflow. Which is when I decided the rb20det was not for me.
so what you decided to build an rb30? must have pretty crazy torque
huh?? Someone correct me if I'm wrong but that fuel map looks like its all over the place.
I'm assuming the bottom graph is AFR's & not boost pressure & therefore should be alot flatter.....anywhere between 11.5 - 12.2 depending on your preference.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
