impressive curve there Dale
Cam gears help a lot to produce that curve.
Have a look at the thread I started on NS about playing with the cam gears.
http://www.nissansilvia.com/forums/index.p...howtopic=318617
Edited by D_Stirls
I think it's just under 4000rpm. It's a GT2871R 52T.
This graph is the GT2871R Vs' my old T28 at similar boost. This shows it's not so much about when peak boost is but more the flow at certain boost levels.
As you can see the T28 produces boost a lot earlier but even with less boost the GT2871R isn't far behind. In fact the 2871 curve is even better now, because after that run we fixed up the hole in the bottom end which was caused by the secondary butterflies opening too early for the bigger turbo.
Edited by D_Stirls
i cant help but think that was a stab at me?
Lol Craig im talking stock interior vs stock interior
Ryan, i definately need some brighter lights and gripper tyres i think. The Wanli's show their limits in the hills.
I just bought some 6000k globes off 666DAN so im there with lighting, just need a bit more power and a bit more grip i think.
Just wanted to give a big thumbs up to Ricc @ Auto Perfection! :P:D:thumbsup:
Had 20% tint done on the legnum windows & alarm installed on Tuesday. Excellent job, 2nd to none customer service. Great guy and great job - very happy! :)
*note: price was also fantastic thanks to Steve's negotiating skills ;)
The 206 is a gentlemens agreement. Everyone knows that the r32 gtr, 33 gtr and 34 gtr all werent 206. Go and get your GTR dynoed then let us know :)
haha well ive got a few small things i need to do first:
buy and install imobiliser
buy and install turbo timer
buy and install new gear and handbreak leather
strip paint off front lip (return to original mat black)
also im chasing a 2wd switch!! i tried PM'ing one bloke on here who sells em but never heard back ;)
then i'll go get a check up tune and see how much she's got stock then move on from there :)
cheers for the heads up, i needa get some work done aswell
Well I just got a quote from All Type Crash, they said 300 to paint my (brand new fibreglass) front bar and $50 an hour to fit. Im hoping its going to fit pretty well and won't take longer than 2 hours. How does that quote compare with your experiences guys?
Edited by Damo_R34
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
