impressive curve there Dale
Cam gears help a lot to produce that curve.
Have a look at the thread I started on NS about playing with the cam gears.
http://www.nissansilvia.com/forums/index.p...howtopic=318617
Edited by D_Stirls
I think it's just under 4000rpm. It's a GT2871R 52T.
This graph is the GT2871R Vs' my old T28 at similar boost. This shows it's not so much about when peak boost is but more the flow at certain boost levels.
As you can see the T28 produces boost a lot earlier but even with less boost the GT2871R isn't far behind. In fact the 2871 curve is even better now, because after that run we fixed up the hole in the bottom end which was caused by the secondary butterflies opening too early for the bigger turbo.
Edited by D_Stirls
i cant help but think that was a stab at me?
Lol Craig im talking stock interior vs stock interior
Ryan, i definately need some brighter lights and gripper tyres i think. The Wanli's show their limits in the hills.
I just bought some 6000k globes off 666DAN so im there with lighting, just need a bit more power and a bit more grip i think.
Just wanted to give a big thumbs up to Ricc @ Auto Perfection! :P:D:thumbsup:
Had 20% tint done on the legnum windows & alarm installed on Tuesday. Excellent job, 2nd to none customer service. Great guy and great job - very happy! :)
*note: price was also fantastic thanks to Steve's negotiating skills ;)
The 206 is a gentlemens agreement. Everyone knows that the r32 gtr, 33 gtr and 34 gtr all werent 206. Go and get your GTR dynoed then let us know :)
haha well ive got a few small things i need to do first:
buy and install imobiliser
buy and install turbo timer
buy and install new gear and handbreak leather
strip paint off front lip (return to original mat black)
also im chasing a 2wd switch!! i tried PM'ing one bloke on here who sells em but never heard back ;)
then i'll go get a check up tune and see how much she's got stock then move on from there :)
cheers for the heads up, i needa get some work done aswell
Well I just got a quote from All Type Crash, they said 300 to paint my (brand new fibreglass) front bar and $50 an hour to fit. Im hoping its going to fit pretty well and won't take longer than 2 hours. How does that quote compare with your experiences guys?
Edited by Damo_R34
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
