impressive curve there Dale
Cam gears help a lot to produce that curve.
Have a look at the thread I started on NS about playing with the cam gears.
http://www.nissansilvia.com/forums/index.p...howtopic=318617
Edited by D_Stirls
I think it's just under 4000rpm. It's a GT2871R 52T.
This graph is the GT2871R Vs' my old T28 at similar boost. This shows it's not so much about when peak boost is but more the flow at certain boost levels.
As you can see the T28 produces boost a lot earlier but even with less boost the GT2871R isn't far behind. In fact the 2871 curve is even better now, because after that run we fixed up the hole in the bottom end which was caused by the secondary butterflies opening too early for the bigger turbo.
Edited by D_Stirls
i cant help but think that was a stab at me?
Lol Craig im talking stock interior vs stock interior
Ryan, i definately need some brighter lights and gripper tyres i think. The Wanli's show their limits in the hills.
I just bought some 6000k globes off 666DAN so im there with lighting, just need a bit more power and a bit more grip i think.
Just wanted to give a big thumbs up to Ricc @ Auto Perfection! :P:D:thumbsup:
Had 20% tint done on the legnum windows & alarm installed on Tuesday. Excellent job, 2nd to none customer service. Great guy and great job - very happy! :)
*note: price was also fantastic thanks to Steve's negotiating skills ;)
The 206 is a gentlemens agreement. Everyone knows that the r32 gtr, 33 gtr and 34 gtr all werent 206. Go and get your GTR dynoed then let us know :)
haha well ive got a few small things i need to do first:
buy and install imobiliser
buy and install turbo timer
buy and install new gear and handbreak leather
strip paint off front lip (return to original mat black)
also im chasing a 2wd switch!! i tried PM'ing one bloke on here who sells em but never heard back ;)
then i'll go get a check up tune and see how much she's got stock then move on from there :)
cheers for the heads up, i needa get some work done aswell
Well I just got a quote from All Type Crash, they said 300 to paint my (brand new fibreglass) front bar and $50 an hour to fit. Im hoping its going to fit pretty well and won't take longer than 2 hours. How does that quote compare with your experiences guys?
Edited by Damo_R34
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
